You had all the electronic nannies off right?
And yes that link is my favorite and I re-read it regularly to get the crap people spew on forums out of my head... ew.
So first things first:
-nannies off
-start with matched tire pressure, chalk or grease marker your tires on your runs and add more to fight rollover on sidewall- I found matched worked pretty well but I was on stock tires so it was futile, though a s***-ton of fun
-EMPTY the car, all mats and such, spare tire etc
-Always do the shortest distance line and edit your throttle input to stay on that, it may feel slow but you'll be surprised
-pick a run in the middle of your runs and make yourself a little uncomfortable, you may learn something- my car was narrow enough to go balls to the wall through a section and the brakes good enough for me to jab em and turn at a right left right lane change style obstacle and
-get CLOSE to the cones, while working the course after my heat the guy who was behind me at my station applauded me for using every inch of the track, he has a mini cooper S that ran a second behind the event-winning Z06
-slalom: remember when changing directions in a slalom, if you went around the left of a cone 50% of the right turn is just un-turning from the previous one- so turn earlier than you thought
Pits: when your run is over, use the brakes as little as possible, windows down, heat on high, engine running, and pop the hood, then turn the engine off after a minute or so but turn key back to on position to keep fans going until heat in heater core is dissipated (cools oil, cools coolant faster)
-while car is cooling, check tires for sidewall rollover and increase pressure and remark tires!
Get a nice 4 wheel alignment from a shop that's performance based and they'll ask you what you do with the car and guide you to some settings that'll loosen up the rear without a sway bar. I definitely got the rear out a bit with some high speed jabs to the brakes while turning- abs helps you from crapping pants in those situations.
