Took my car to the track on Saturday for the first time. The car performed fantastic, never even tried to overheat. Other than destroying a couple tires, the car was just fine. Well, at least that is what I thought. Found this after driving to school today. The underside of my car is absolutely coated with transmission fluid.
<iframe src="https://onedrive.live.com/embed?cid=5AA886B2BC80B78C&resid=5AA886B2BC80B78C%21284&authkey=AOkIdh9n2n9Q0jg" width="320" height="180" frameborder="0" scrolling="no"></iframe>
I had no leaks at the track, so this somehow happened sometime afterwards. I am trying to figure out where the leak is coming from. It is pretty significant, and only seems to leak when the car is on and in gear. I put the car on jack stands and let it run at about 2,000 RPM in first gear for around 30 seconds. This resulted in it leaking around 2 table spoons of fluid. I couldn't locate any of the gaskets leaking. It seemed to be coming off the top, as the square part in this picture illustrates.
<iframe src="https://onedrive.live.com/embed?cid=5AA886B2BC80B78C&resid=5AA886B2BC80B78C%21283&authkey=AMHAxl6lKObmnr0" width="226" height="320" frameborder="0" scrolling="no"></iframe>
I am thinking it might be the O-ring on whatever the "lock brake" part is, as there isn't much else in that area that could leak. Does anyone know what that is, or have any experience with it leaking?
