Lowering issue
Farmp5
Mazda protege5
Hey whats up every one, so I've tried searching for this but couldn't find the answer. hopefully one of you can help me out. I lowered my 2003 mazda protege5 on some kyb gr2 struts with megan racing springs. Everything went on smoothly and it rides great except the rear left is making a clunking noise. I haven't taken it in yet for an alignment. So any of you guys had this type of issue after lowering your car? also my abs light came on too after lowering it. any help would be greatly appreciated!
Check all your abs wires and sensors to make sure all are intact and securely bolted. Make sure swaybar link nuts are tight and strut top nut is tight.
I replaced the sway bar link when i was lowering it because they were bad. also any one know where i can get shorter sway bar links for the front?
