- Mazda, CX-5 Grand Touring
Has anybody installed LED Foglight Housings? If so, I need help on where to tap in with the accessory wire within the cabin or in the engine bay. Any diagrams or videos or anthing TIA!
I tapped mine inside the cabin where the sunroof fuse is, I used the add a fuse and a basic switch. I fished the wire through the cabin with a coat hanger.
Don't just tap into a wire, buy the add a fuse and go from there.
sounds like the OEM installation instructions might help:
http://ep.yimg.com/ty/cdn/yhst-24809172479195/cx5foglamps.pdf
looks like all the wiring should be in there already...
Thnx for that! I'm trying to install the aftermarket foglighy grille with the led strip.
Sent from my iPhone using Tapatalk
