funksilver07
- 2007 Sunlight Silver Mazdaspeed 3 GT
Anyone using the J-Speed short shift plate? Looking for a comparison to the JBarone version. Thanks for any response and feedback.
I am not trying to start an online argument, I welcome JBarone's, as well as anyone else's opinion regarding my J-Speed SSP.
I have done much research on this part before releasing it to the public.
"When investigating the shifting mechanism on the Mazdaspeed 3, I noticed that it was possible to shift gears with just one finger. This tells me that there is a small amount of effort required to move the shift linkage on the transmission, certainly machined aluminum can handle this stress. The J-Speed SSP is made from a solid billet of aluminum then machined to its final form; this allows the strength of the aluminum to stay intact. The material removed from the center of the plate contains rounded edges which eliminate the possibility of stress fractures in those areas."
"In regards to using the stock counterweight with my SSP, I fail to understand how this would damage the synchros and gears of the transmission. If the stock counterweight is of the wrong mass, why would Mazda install at the factory?"
...the plate adjusted in the center because it allows even shift throws for the odd and even gears...
When you decrease the radius, and the force applied is increased, the speed is increased too. When you have too much mass moving at high speed what happens when it comes to an abrupt halt? The Mazda weight was designed for the factory configuration, not for this configuration. Why do you think it's recommended to change the weight after installing a short throw shifter?
I hadn`t considered that changing the leverage would result in effectively slamming into gear every time the shifting gets a little "spirited".
Does anybody sell just the lighter weights? I really don`t want to hack up my stocker.
jbarone, the stock counterweight weighs 16.3 oz.
at what point deformation would occur from stress...
