jonridinhi
- 2001 MP3/2010 MX5/1996 MILLINIA (donor)
So I sold the MP3 and got a new toy to play with....
1987 Mustang GT
MOD LIST:
Storman norman Hood with pins
saleen wing
16" ROHs rims
weld on frame supports
135 amp alt
MSD 6a multiple spark discharge
MSD distributor
MSD super conductor wires
1.7 roller rockers
March Aluminum Underdrive Pullies (Alt., Crank and W.P.)
A/C and Smog pump deleate
Cobra Radiator
16" push cooling fan
14" pull cooling fan
Adjustable thermo switch
CAI w/ 4" K&N air filter
Adjustable FPR
Short shifter
BBK Shorty headers
Pypes catless h pipe
Super 44 Flowmaster cat back exhaust
Tint: 35% sides and 20% rear
Gauges:
AEM Uego Wideband
Auto Meter Sport Comp-
Vaccum
L/O pressure
J/W Temp
Voltage
Fuel Tank Level
And finally the giant 5" Auto Gauge Tach (will be removed once I can find a replacement dash)
12JAN11: Just drove with prdracing late last night to go pick her up. Just washed and waxed the salt off of it from the trip back and parked it in the garage for now.
13JAN11: I took 10 miles of wireing out of it today and found the MSD ignition was not wired in, neither was the speakers to the head unit and that the previous owner had multiple amps running all at the same time. Also none of the gauges or the tach were wired in and 3 random toggles up under the dash.
I removed the A-pillatr gauges and the tach. The car had an alarm system and half the wireing was just cut and left. It is a mess but coming along.
Researched into my sticking gas pedal and found it to be the cable getting stuck but in the process I looked at the TB and discovered it to be way to clean for the milage (and possible egr deleate). Did further investigation and found that it appears to have the blue summit rocker roller arms installed, also appears to have no sludge or build-up on the top end at all. Will pull VC's in the days to follow. It has one area of rust on the frame and I wam waiting for one of the guys I know who owns his welding service to come look at it and tell me if the engine needs pulled. If so what out for the bay will turn into, it will get the focus instead of seats and suspension.
1987 Mustang GT
MOD LIST:
saleen wing
16" ROHs rims
135 amp alt
MSD distributor
1.7 roller rockers
Cobra Radiator
Adjustable FPR
Short shifter
BBK Shorty headers
Gauges:
AEM Uego Wideband
Vaccum
L/O pressure
J/W Temp
Voltage
Fuel Tank Level
