K Kidplay11 Member : Mazdaspeed protege Feb 26, 2013 #1 Can someone install thes before and how ? B cable singnal to ecu or to the maf? Wich one is the b terminal on the maf ?pic is someone have pliz thanks
W Wheredjaredgo Member : Mazda protege speed Feb 26, 2013 #3 I hooked mine to the MAf -b signal "green wire" and got a lean check engine code same day... So I immediately took it off and gave up on it because I have no Wideband
