Jeff@Tri-Point said:Axxis Ultimates front and Posi Quiet Ceramic rears, why did you change from your setup?
I just felt the car was still rolling too much in the front and decreasing tire life by killing the outside of the tires and overheating them. I think I had 450# springs up front at the time. I was on R' comps though so the extra grip probably caused a lot more roll in the front than your setup that a lot of negative camber couldn't overcome. I was also on far less engineered struts so the springs weren't controlled very well. I know several STX MSPs that swapped out for the smaller Protege5 front swaybar, but no one has really done much reporting on that. I'm not very familar with the posi Quiet pads. I know they are supposed to be equal to stock. I've got stock pads in the rear of my car and on street tires I can lock the rear up pretty easily. It's not nearly as bad on R' comps, but thats probably because I'm more sensitive to them and subconciously adjust so that I don't lock them up. I've been thinking of installing a bias valve, but I hate working on brakes.
