Installshield 2
Gothenburg Superiority
thanks guys.
Tweety: Originally that is what i was going to tap, but i often use that for charging a phone and GPS system at the same time...which shouldn't of mattered, as i'm sure these gauges draw very little relatively...but since i had two completely free 12v lines just capped off in there, it was much simpler to just use that...probably not the best idea for someone using the factory stereo power leads, but my stereo recommended its own...and came with them...this also allowed me to get everything done in a matter of minutes, instead of pulling the entire HVAC system and bezel out just to get into the cig lighter area...
BR: The oil pressure sensor mounts into the plate adapter i bought, which sandwiches between the oil filter and block. So i didn't need to use the stock sensor location in any way at all...the temp sensor mounts into the same plate, so i was able to install that stuff with sealant on a bench, then mount it on the car and attach the sensor/ground wires...
I'm also starting to second guess myself about that clock. I reset it this morning when i discovered it was ~10 minutes off, and so far today, its remained accurate...I first did the 'daisy chain' ground thing mentioned in that how to, yesterday...which messed up the temp reading and made it spike to max...so i either fouled up the ring terminal, or it wasn't touching the right part of the sensor...or something...so i jacked the front up again real quick, reached under and just disconnected the small link from the temp to pressure sensor ground i had made...temp sensor worked perfectly after that...
but...what i can't remember is if i disconnected the battery when i did that...if i did...that is the difference with the clock, as it would've taken roughly 10 minutes...and i know i didn't reset that clock when completely finished because i wasn't thinking about it chasing the oil temp problem haha...
that might be all it was...i guess i won't know for sure until tomorrow morning again...
