shanneliszewski
Currently when my car is in nuetral or park and running it has a rough idle when i put it in drive or reverse the car has a heavy jerking also the rmps needle is going slightly up and down at all times. when i am driving it i will get a jerk and the O/D light comes on and starts flashing, when i stop at a light i can put it in nuetral and rev the engine the O/D light goes back to normal.
the car has 149,000 miles on it, i am the second owner purchased the car with 70,000 mile on it and had the plugs replaced and drained and filled all the fluids when i purchased it.
i have replaced the following
air intake accordian hose which had a crack
Mass Air Flow sensor
speed control sensor
radiator temp sensor
spark plugs
wires and coil packs
cleaned throttle body
new battery
i took the car to ammco and they told me that i have a bad egr valve and with the O/D the mazda shop told be the wires on the O/D button may have become disconnected do these sound right or what are your thoughts?
spark plugs
new battery
