First off, mad props to the OP and everyone who has had input to this thread over the years. I registered here just for this thread. I know this is an old thread, but I thought I'd bump it for some information that I haven't seen discussed in great detail (or at all).
I'll be tackling a clutch/FW/LSD install on my G35MR early in 2012. When speaking with some shops who sell the Mfactory LSD, they recommend that I replace the races when replacing the diff bearings. One proprietor recommended I take my tranny to a proper tranny shop as there are 'specialty tools' required for setting the bearing preload. I haven't seen any conversation here about replacing the races and setting bearing preload on the diff bearings; did anyone undertake this task? If so could you please provide some tips and comments on what you did, or what to look out for?
As far as I'm aware the procedure is pretty straight forward. You remove old the races and shims from the case, install new races without shims but don't press the races all the way in. Install the LSD and case, and torque the case shut; this should press the races in place. You then measure the gap where the original shims were using a feeler gauge, and add 'x' thousandths for the preload to figure out what size shim you (I) need (I believe in my case it is 0.006). Then you take case apart, remove LSD, remove race, install shim, and reassemble. Seems straight forward to me, but I was thrown off when I was advised to take my tranny to a tranny shop; I'm wondering if I'm missing something, or if my methodology is lacking in some way.
Thanks again for the awesome thread, and any feedback anyone can provide about shims, races, and bearing preload.
