Yes, you read it right...2 HRS
minimum experience requiered...
no more putting away that project because of difficulty!!!
it can be done in 2 hrs top unless you are a ******* retard..
Here's how it is done...
Remove intercooler to throttlebody pipe (either plastic or hard pipe)
remove throttlebody cable
remove plugs from TPS and IAC
remove two nuts from throttle body
remove two screws from throttle body
now, you can see rear motor mount....
next
use 17 MM wrenche on the passenger side of the bold that goes thru the motor mount
use 17mm with breaker bar
remove the big bolt...
now, remove wiring harness by removing nut with 10MM on top and 10MM on bottom....bottom one can be acomplished by using a small ratchet and just giving it two or three turns, after that it become finger tight...
bend bottom screw with something towards the passenger side..you can always bend it back...
use same 17 ratchet prefferebly 1/2" insted of 3/4" drive
use one of those little things that allowes you to use the ratchet at an angle
then use various extensions so that it becomes long enough that goes over the top of the engine.
then with proper tools, use a breaker bar...these nuts are very tight!! use air tools if so nesesary or available..
Remove old motor mount (just jiggle it until yu find a way for it to come out..believe me...it does come out thru the top...)
insert new motor mount same way old one was removed..
insert the 3 nuts, tight in same way as removed...
insert big bolt thru the motor mount, if it doesn't go thru, have a jack under the car and lift from the back of the transmission, have someone do the lifting until the bolt goes thru..
install nut on the other side same way as you did unbolting it
reinstall harness protector and use the top nut only, unless you can also use the bottom one.
reinstall throttle body....if gasket wasn't damaged in the process, use some RVT sealant just to make shure of no leaks...otherwise, get a replacement gasket, you can also use only RVT sealant gasket maker
reinstall throttle body cable
reinstall throttle body nuts and bolts
reconnect TPS and IAC and any other plug you unplugged
reinstall hard pipe or stock plastic pipe
reinstall everyhting else you may have removed
Total Time: 2HRS
Outcome? PRICELESS
no more wheel hop...use in conjuction with front motor mount.
Here are some pics...
you can thank me later...
enjoy
someone move this please
next
Total Time: 2HRS
Outcome? PRICELESS
enjoy
