How to make the fog lights an independent switch.
Overdonebacon
2003 Mazda Proteg5
Is there a way to modify the fog light switch so you can use it when the high beams are on and as well as when the headlights are off?
I cut the red wire that goes to the relay and extended it to the battery then put a fuse holder in between the wire with a 10 fuse so I can have my fogs on with out having to turn any of the lights on now I'm trying to figure out which wire is the one that goes to the warning chime when u leave your lights on just incase I forget to turn off my fogs
Latest posts
