Laser03pro
- 1995 Miata
I knew there had to be a hole somewhere close companys just dont do that sort of thing there had to be some access.
Velocifero said:I had one of the welded nuts inside the crosmember break loose when I was installing mine, it was my own fault, anyways, you can get a longer box end in the crossmember and i ran a bolt out from inside the member out. let me know if you need some pictures of how I did this. It is possible and you will not need to replace anything or cut any holes in it, just takes a simple tool and some patience.
Laser03pro said:You have to use a good quality synthetic lube and lots of it.
Bala de Plata said:Formula 5 Prelube from Energy Suspension has impressed me - http://store.summitracing.com/partdetail.asp?autofilter=1∂=ENS%2D9%2D11104&N=700+115&autoview=sku
Also has teflon
Laser03pro said:Super lube is also sold here but at a higher price they recamend it and they sell alot of chassis parts. As you can see only lube poly bushings with synth grease.
http://spohn.net/product.cfm?productid=1322
That ES stuff im sure is good s*** too Bala.
Laser03pro said:Stock bolts worked fine that just might be incase your stockers are all rusted up.
