Yes.Protege__Owner said:Thanks chuyler and astral for the follow up. Now let me get this straight, assuming I'm shifting from 3rd to 2nd... I should step on clutch, shift down to 2nd while simultaneously rev matching and then release clutch?
Since blipping the throttle (rev matching) means that you're giving it a bunch of gas, you obviously would be coming off gas somewhat. It depends on the car, but basically you don't want to keep the revs any higher than the revmatch point until the clutch is fully engaged. Once the clutch is fully or 90% engated, you can smoothly transition into full throttle. This may mean that you have to fully release the gas pedal after blipping the throttle, or maybe you have to give it some gas. Depends on the car and the revs.Protege__Owner said:So should I let go of the gas pedal as I'm letting out the clutch or do I just release the clutch while I'm still on the gas?
The way you know that you're giving it too much gas while letting out the clutch is that the revs momentarily shoot up and then they fall back in line because the clutch is now fully engaged.
The key is to be smooth. Be as smooth with your shifts as possible and fast shifts will come naturally.
