While poking around in the setup menu, I unthinkingly enabled information sharing, thinking it'd be no big deal. Now I have another annoying permission screen to respond to at every startup.(pissed) Anyone know how to disable this nuisance?
I would imagine you just go back in where you enabled it, it should say enabled and just highlight it and turn the command button to disable it.
It was enabled in the setup menu; the menu item disappeared afterwards.
Edit: I poked around in the menu system some more and found a Reset Defaults option. Problem solved.
Thanks for your suggestions! (drinks)
Additional Edit: Started engine, annoying screen returned. Back to square one (scratch)
Do a search through the CX-5 Audio folder for 'Disable Information Sharing". There's an older link that provides some info that may help you remove the message.
The user mentions something about it being embedded in one of the setup screens.
