Maybe I missed it in the manual, but which fuse number controls the DRL's ? I am considering a rocker switch to give manual on/off control to them if I can figure it out.
I don't think you can pull the fuse on the 2nd gen.
Got it on the first try. Not sure if I'll leave it that way though, I actually prefer the way it looks with the Parking Lights switch on, i.e., center round headlight off but halo and flat side lights remain on. It's technically illegal to drive in my state with just the parking lights on but this configuration looks similar to many other manufacturers' DRL's so I'm sure the popo wouldn't notice. I'll get stopped for the 25% tinted side windows long before having the parking lights in motion.
Again, for the record, here is an official copy of instruction to disable the DRL function for CX-5 obtained by bigtex from his Mazda dealer:I copied this from somewhere, saved on my computer, but download the PDF in post #1, it has a picture for you.
I start with my lights switch in the off position.
Engaged emergency parking brakes.
Push ignition button twice.
Step on the brake and keep foot on brake the whole time.
Turn light switch to parking lights then back to off 5 times really quick (have to scroll pass auto if you have auto lights).
Then hit the hazards 10 times really quickly (basically on and off 5 times)
Turn light switch to parking lights then back to off 5 times again.
Disengage emergency parking brakes.
Release foot from brake pedal.
Push ignition button once to turn off.
Your DRL should be disabled now. Repeat steps to enable
Is this the file:
Yes, this way is the best looking setup on LED accent DRLs. 2016 and 2016.5 CX-5 have this way.I agree, that's the best look we can get on KFs.
Good question. On my 2016 CX-5, since the DRLs dont use low-beam LED headlights, LED DRL halos dim a bit when you turn the light switch to parking light position. Also the amber halogen parking lights / turn signals will be on (although I disabled the amber lights on parking).Don't the DRLs come on with the parking lights when you get in gear [when they're not disabled]?
Traction control can and does safe lives...
...DRL doubt factors into anything calculatable.
Have you ever pushed a car w/ these features to its limit to 'deal' with what you are asking those systems to compensate for? If you have, then you would not make such statements.
Are you saying that these modern safety features actually kill more people than they save?
It helps put drivers in situations most should not be in.
