Hello Everyone,
I've got a 2000 protege that now has 158k repair free miles on it (ok the camshaft sensor went out last year- do 5 min repairs count?)
The check engine light went off- and the code was for the catalytic converter- verified by the mazda dealer. There are no other codes at all. The haynes manual is useless. How do I remove/replace the converter and the manifold heat shield?
Before doing a repair I always look around to see where problems could arise before I do anything- well the bolts that attach the heat shield to the manifold seem to be the first problem. They are corroded and pitted and the fit is sloppy on the socket. I've been using PB blaster to no avail- and I don't want to shear the bolts off. What do I do?
So as a back up plan, if in fact I do shear off the bolts, I contacted a machine shop to see if the would be able to retap/clean out the threads in the manifold. The shop said that it is often easier to remove the whole manifold from the block with the converter attached and disassemble on the bench. Which, after looking where the five bolts that attach the converter to the manifold seems like it might be the case.
Also, there are a lot of aftermarket converters. How do these stand up to Original Equipment?
I will post my progress to the "how to" section of this forum, since other people will have this same problem in the future.
Thanks,
Steve
Thanks,
Steve
