go it thanksxtrememps said:Read above carefully, I just wanted to get to the wires that connect to the sub. I didn't know you could remove the grill...so I attempted to take off the plasic cover on the bottom to get to them. Now I know you can take off the grill hehe.
Is the amps power light on? If not, its the fuse under the hood.xtrememps said:Maybe....
Then there is a problem with the fuse for the radio. Probably in the kick panels fuse box. IF the radio won't turn on then neither can the amp.xtrememps said:The amp's light isn't on. The radio won't flip over either. Nothing. I'll defeinitely give the battery trick a try, though..and check the fuses. (sad2)
