Hey Guys-
Here is where I'm at... I've got the Injen, HiBoost, and GReddy Type-S. I think I might have a couple of the couplings in the wrong spot because my 45 degree L pipe right after the S-pipe keeps popping off. The directions didn't tell what coupling goes where on that side of things.
The way I've got it now is between the S-Pipe and L Shape, it's the short big (not sure of size.. sorry). Then on the other side of the L Shape Pipe, I've got the hump coupling that connects to the BOV casting. Then between the casting and Throttle Body, it's the long big coupling.
Are the short and long couplings in the wrong spot?
Also, when I was testing everything out, somewhere between 3-4k RPM the car would bog really bad.
Right now, I'm using the stock vaccum source for the Type-S, and from what I've been reading, it's better to give it a dedicated vaccum. Can someone point me to a thread or tell me how to go about this?
I worried about what is causing it to bog. It might of been the pipe popping off because it bogged, then the car died. When I looked, the pipe was off.
Also, to run the Type-S, I've seen mixed opinions about running it as-is, or getting the 19mm adapter. Is the adapter what makes the BOV recirculate?
This is a good learning experience for me, which is why I'm working through it and not having it installed. I'm just getting tired and slightly frustrated.
Any/All help, advice, opinions would be appreciated. If I need to get pics of it, let me know.
**EDIT: Even though I ordered the Type-S upgrade from Hiboost, am I still supposed to get the HKS BOV also? Or no? I didn't get both, just the type-s, and wanted to make sure.
Thanks!
Jake
Thanks!
Jake
