HiBoost powered car makes 343.9 WHP at 22 psi
The intercooler is the same core but different piping.
Juan
you should refer the people that dont think the IC is able to handle 300+WHP to this thread to show them what it is capable of.
good god. how much timing would the stock computer run at 22psi? You're so lucky to be able to run the stock coil packs! I'm blowing out spark at 17psi with a .025" plug gap on the Ford EDIS coil pack. grrr!! But how much timing is that anyways?
-Mateo
-Mateo
What ecu are you using? Why are you using the FORD EDIS PACK? The stock coils are way better than the FORD EDIS.
I also run the stock coils in my yellow P5 at 22 psi.
Juan
