i installed four months ago and i did my first oil change with it. let me say it makes life that much easier put piece clear hose on and into the oil drain pan hole easy as pie
MikeM., that's funny... The major reason why people want Fumoto valve installed is the convenience of NOT taking the drain plug off. You're asking people to remove the Fumoto valve to drain out the last bit of old oil? No way Jose!When it's done draining, do you remove the valve to let the last bit of old oil to drain out or just call it "good enough for government work"?i installed four months ago and i did my first oil change with it. let me say it makes life that much easier put piece clear hose on and into the oil drain pan hole easy as pie
