full coil on plug ignition setup
teeter
Sorry for the newbie Protege5 question. I searched and didn't come up with anything concrete...
So the stock protege5 ignition is a bastardized version of true coil on plug...and people seem to have issues with it a lot.
I'm curious if anyone has retrofitted a full set of true coil of plugs...thus eliminating the plug wires all together...
I come from the turbo 4g63 mitsubishi world (also a direct fire waste spark system) and this is a relatively common change to increase the reliability of the ignition system... It seems like it would be a relatively easy thing to engineer up...
john
Would require special valve cover & power source for 2 more coils but not overly crazy to make. Could maybe use an adapter on the mounting points already there to give other 2 coils something to bolt to. Electrical doesn't seem that far fetched but the improvement in reliability & performance gains would probably deter most. Just my 2 cents.
what problems have people been having?
I know of more than on 300+ hp protege 5's that are using stock ignition systems
Matt
Corksports drag Protege used 4 coils, but they used a standalone to control everything from what I remember.
