i never meant to imply that you would see the gains that u would see out of NOS, that would be stupid to expect but you will see a gain in both power and torque maybe about 10-15 hp with a good fuel cooler. pretty good considering most small mods would give you about 7 like exhaust or headers and things like that. and like trick said if u want to spend a little more i have seen professional fuel coolers that use compressors to cool the fuel down even more and i would expect to see larger gains, but like i said dont plan on doing something like that unless you also plan on building your internals up also cause you will cause damage to your engine
