SpeedProtege
- 2008 Mazdaspeed3
My '08 speed3 has 45k miles on it and has a solid sounding clunk on uneven bumps from the front end. I checked the sway bar links by hand, then with a pry bar, and made sure the nuts were tight.
Forum searching seems to suggest it is the bushings. I was swapping my summer wheels back on and tried prying between the sway bar and frame and did not get any movement.
If you have fixed/replaced the bushings was there any noticeable play to tell you it was bad or did you just R/R?
I hate to replace parts when I can't confirm they are bad.
Thanks,
Bryan
Thanks,
Bryan
