Front lower control arm leak?
HaggisSP3
Speed 3
Does anyone know if the rear bushing on the front LCA is fluid filled? (it's the bottom right bushing in this image http://www.rockauto.com/catalog/moreinfo.php?pk=1282572)
I was swapping from track to street pads and noticed oil/fluid on the bottom of the bushing. No fluid on top, so it appears that the bushing is leaking?
If it is leaking, do these have to be replaced in pairs? Or can I do one side?
Thx
Yes, the rear bushing is fille with silicon oil. if it's leaking then you will need to replace it.
