Question: What is a device that improves gas flow control to the point that the manifold is pressurized earlier, to a higher peak number, and for a greater portion of the RPM band?
I would accept either "exhaust" or, in this case, "a Forge valve".
No one will argue that an exhaust system can gain power, the same can be said of our valve. A more efficient exhaust decreases restrictions to lower pumping losses. Our valve decreases throughput to lower lost pumping.
guessing it still makes the ping sound
it sounds exactly like this:
pling!
I'm not sure if my BPV was leaking or not but with the Forge BPV on, the car does not buck between shifts. The car is much smoother and boost does not drop off badly between shifts as it did with the stocker.
I kind of have to agree with this now that I have had the Forge off for almost a week. I definitely felt like the car held boost better with the Forge, I just hope I'll be happy enough w/ the Turbosmart, otherwise I might end up going back to the Forge lol
Just rig your horn to play the original Zelda theme and every ride in your car would be a trip down memory lane.
girls, geezyeah pretty much
mine was sticky and caused erratic boost which i suppose means leaking. I bought the valve because of good feedback from the forum and intelligent responses from patty @ I like the theory of the simple spring adjustment. i had a very nice turbo xs in hand but no one could tell me what adapter I needed. So with the Forge I go. it does what is supposed to do, well. A young fellow around here has a turbo smart valve and that really chings!to me is sounds like coin machine. enough said. I can say one thing, it has taken care of my 2188 and 0300 codes. Which in turn means that my stock bypass valve was indeed leaking and defective.
