I just pasted the 50k mark on the 4Runner and think it's time to change out the fluids.
I was thinking Late Septmeber/ early October (Oct. 11th if we do it in Waterford).
I can do it at my condo (Bristol, CT) anytime, or travel to someone else's garage or I'll be housesitting my folks (Waterford, CT Oct. 11th). The only issue with that is I'm limited on what tools are available there.
My initial list is:
Differential (both front and rear) and Transfer Case Fluids: www.toyota-4runner.org/maintenance/...ntial-transfer-case-fluids-pics-included.html
Transmition Flush and Fill: www.toyota-4runner.org/maintenance/42071-diy-non-sealed-transmission-service-4th-gen-t4rs-prior.html
Spark Plugs: NGK Iridium IX Part #LFR6AIX-11
Transfer case fill gasket 90430-18008
Transfer case drain gasket 90430-18008
Front differential fill gasket 12157-10010
Front differential drain gasket 90430-24003
Rear differenyial fill gasket 12157-10010
Rear differential drain gasket 12157-10010
Any other suggestions?
I'll finalized the detail in this first post once I get some feedback from everyone.
oh and don't forget I own a toyota now, so make sure you're okay with touching a non-mazda before you sign up lol
My initial list is:
