- Hemi Ram, 71 Plymth Scamp, 71 Plymth Duster 340, 69 Dart 340/4sp
boostisgood said:Ohhh educate me please. Or how about I educate you.
First, you have 2 types of Oxygen sensors in ODBII cars.
1. Zirconia sensors, which produce a reference voltage on thier one (Between 0mV to 1000mV with 450 mv being Stoichiometric) it compares the oxygen content of outside air which is 21% to the content of the exhaust. This is to allow the PCM to go rich/lean rich/lean so the Catalyst will operate properly and burn off the NoX and produce the water and C2O for emissions.
2. Titania sensors. They do not produce a voltage but act as a normal sensor in your vehicle and return a reference voltage back to the PCM (resistance type sensor). This sensor ACTUALLY detects the ammount of air in the exhaust and returns the signal voltage to the PCM. It does not use outside air to compare.
What your front oxygen sensors do is called cross count. It will go above and below .450 V (again that is stoich) and feed that info to the pcm so it can ad and take away fuel as needed for emissions.
now with that brief explanation of Oxygen sensors (and toyota uses a 5v in some cars) I will now ask you these questions.
1. Are you a tech or an engineer of PCM programs?
2. If you are and use a scan tool (Genysys Snap on red brick or OEM like the ford/mazda WDS) do they show what the octane rating is along with the data streams of the sensors? Ill actually answer that one for you NO THEY DONT. Now if the octane rating is that important, wouldnt you think that if the PCM was capable of determining the rating via what the sensors are sending it, it would ? Case in point, when my engine blew, Mazda could not gather the info on the type of gas in my car based on PCM/ECU data provided nor from the freezframe info from the CEL. If the PCM could determine it, should it not have been displayed ?
I could go on forever, but I would rather go play with my kids now.
What are you talking about? You answered your own question. A O2 sensor reads the oxygen content in the exhaust stream. Period, end of story. The Oxygen content, nothing else. It doesn't matter what sensor you use.
If it knows everything going in the motor, it knows what it should see coming out. By changing the octane rating of the fuel going in, it changes the oxygen content coming out. It's that simple. I did not come up with this crazy notion one day. It was all explained to us at the Mazdaspeed6 tech. training. On top of that if you went to Engine Management Level 2 class by Vw you would also learn this (New Vw's do the same thing).
Also I assume you mean you blew a MSP motor, totally different pcm's going on here.
And with the pcm's in the Mazda6 and Speed 6 you can determine the octane reading...sort of. Using a new pid called rear fuel trim. It gives you a value that can help you determine whether the correct fuel is being used.
You do not need a egt sensor to read the temperature of the exhaust.
