I'm surprised that there is no ATF sticky in the Transmission Section - I think one would be helpful. I'll throw my 2 cents in below:
Key ATF Notes:
- Quote from this 2008 Mazda TSB 05-005/08: "ATF M-V (TYPE M5) IS NOT THE SAME FLUID AS MERCONV ATF." (here is a link to the document text: http://www.protegefaq.net/tsb/05-005-08.html)
- Mazda part number for ATF M-V (aka Type M5) is 0000-77-112E-01
- Mazda 5 manuals do not specify an ATF change/flush interval at all
- Fluid color can be misleading as guide as a "time to change" indicator, but fluids are relatively cheap vs tranny problem fixes
- Other than Mazda-branded ATF Type:M5 (aka ATF M-V), I am not aware that Mazda publishes a list of ATF approvals or list of other branded products that meet all ATF Type M5(M-V) performance requirements
- See a Type M5 quart label picture here: http://parts.arlingtonmazda.com/products/M5-AUTO-TRANS-FLUID-(0000%2d77%2d112E%2d01).html
- Some companies may recommend their ATF verbally or in writing; there is no documentation for an end user to reference to validate the suitability for use, so use your own judgment
- Not all car dealers use OEM spec or tested/approved fluids (even more so with service shops/quick lubes); even if they sell some branded products, many use the cheapest mystery brand oil they can find for their high volume oils (like ATF) - suggest you inquire about or view any bulk tank or drum where Type M5 (M-V) ATF is claimed to be used
- Flushing machines may be pre-filled with other types of ATF, so if you are to get a flush, would recommend to ensure that the proper Type M5 (M-V) fluid you desire will be used (changing ATF fluids on the fly may or may not be possible with the machine). The "cleaning" flush oil may still remain and mix with the "final" fill oil.
DIY Drain Pan Method ATF Swaps:
- using my personal experience on ramps on a slightly inclined driveway - with hot ATF (at operating temperature) verified to be at the bottom "OK range" dipstick mark before using ramps
- depending on the degree of ATF swapping, buy quarts of ATF Type:M5 (aka M-V) (for ~61% swap/2 drains, buy 7 qts; for ~76% swap/3 drains, buy 10; for ~85% swap/4 drains, buy 13)
- also consider buying 1 additional qt - just in case you burp out a bit or spill - hate to not finish a job if you don't have the right amount of fluid
- gather ramps, tools to remove bottom cover, 8 mm Allen key, catch pan, old flattened box to catch drips/spills, small diameter funnel, jug/container(s) to transfer drained oil into for recycling, paper/shop towels - safety glasses are a good idea too
- remove the bottom plastic cover to reveal the black ATF pan near the driver's side front tire
- use a big ~8 mm Allen wrench to remove the ATF drain plug
- drain into catch pan - I measured ~3.2 qt drained from my pan
- with a vacuum extractor device/pump with poly tubing, I was able to suck ~3 oz from the dipstick tube after the drain pan was empty (without draining from the pan, I was able to extract ~2 quarts via the dipstick tube)
- given the 8.6 qt total transmission capacity noted in my manual, I was able to swap out ~38% (~3.25 qt) of the ATF
- add ATF down the ATF dipstick tube using a small diameter, long neck funnel - BE CAREFUL to pour new in quite slowly or the tube will "burp" air and overflow/spray ATF out the top of the ATF dipstick tube or funnel (and possibly onto you - safety glasses may help here)
- drive around a little to mix new and old ATF well and ensure ATF is hot (operating temp)
- drain and fill again to get to a ~61% swap
- mix, drain and fill again to get to a 76% swap
- if desired, mix, drain and fill again to get to a 85% swap
- going beyond 76%/85% would remove only ~0.8/0.5 qt of old ATF out of 3.25 qt drained- perhaps the point of diminishing returns?
- reinstall bottom cover and validate proper ATF dipstick fill level
Notes:
- Remember to have the ATF at operating temp when checking the dipstick level - and have the car running and level when checking the dipstick
- A vacuum extractor/pump device is helpful to adjust the fill amount if you happen to overfill
- I measured 814 net grams of Mazda ATF Type:M5 ATF fluid per quart (I used a scale to perform measurements) - fill quantities may vary even if the labels say 1 qt
Happy times taking care of your Mazda 5!
Key ATF Notes:
Notes:
