OK, got my DashHawk yesterday...this was my second unit, but I had a Gen 1 before (in my GTO).
One thing to remember: Do NOT install the software that comes with it (on a CD). Download the newest software from their website, and install that instead. It won't allow you to "update" the software to the newest version, so you'll have to uninstall the first one to put on the new one anyway. As soon as you have the software installed, plug the DashHawk into your computer and update it (click Upgrade and choose the file present).
You will not be able to measure boost with the original firmware...it's not even on the list of parameters. Once you update the firmware, you can get a better range of selectable colors (goes from % red, blue, green to 0-255 scale for each), and an easier interface that categorizes the different parameters. It also puts in the boost gauge parameter (boost/vacuum).
It also comes with a little stand that you can place right on your steering column. It does block the lower half of the speedometer, but you can get around this by either mounting it in a different spot, or do what I did and just have the speed displayed on the DashHawk.
I'll take a picture tonight if I have time.
