They'll work much better if you put rubber on them. Just sayin.
problem solved, tires actually mounted easier than i thought they would, though the dismount might end up taking a little skill.
that looks freakin amazing, even from the video i could tell you were so much quicker than before. it's going to be crazy once you get it dialed in.
The biggest difference I think though was how fast we were able to take transitions.
Seriously, they're like flypaper. The transitional response is just silly.How hard these can transition is pretty crazy. It's almost as if the harder you make transitions, the harder they want to hang on. Imagine doing what we did and came straight from 195 toyos, yikes!
Are you still on a 1.6 4:30 rear diff? If so, get used to that rev limiter (drive). Today and last weekend we were on fairly small asphalt lots and we ran out of second pretty fast even with a 7500 rpm rev limit. We thought we could upshift/downshift well enough but it became clear pretty fast that we suck at it lol. 3.90 with a Torsen going in this weekend.
Awesome!
Don't change gearing, just build a motor with a 9krpm redline... (cabpatch)
That too. But even then we'll want to go to at least a 3.9, I think.
I like the gearing bump from the 4.3 right now. I'm still on an ST build motor + Megasquirt. It really bogs as soon as you do anything to get the gears longer. It's good enough, enough of the time, that I'm going to keep this rear end until I build a motor with some more twist. Then yes, a 3.9 or maybe 3.6 will be on the table.
