I have a 4 cyl 2004 Toyota Highlander base model. Here is what I'm finding on the engine specs:
Power: 119 kW , 160 HP SAE @ 5,700 rpm; 165 ft lb , 224 Nm @ 4,000 rpm
2,362 cc 2.4 liters in-line 4 front engine with 88.4 mm bore, 96 mm stroke, 9.6 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder 2AZ-FE
GROSS WEIGHT 5360 lbs
I don't know engines or how to compare this to the 2013 CX-5. Can someone tell me how the power will compare? I'm fine with the power of my Highlander, so this will help me decide if I should just go with the 2013 GT or wait for the 2014.
Thanks so much for the help.
