With 255/55R19 tires on your Michelin Defender LTX M/S, your speedometer and odometer will be off a bit as the tires are a bit larger at 29” overall diameter. The “measuring rim width” is 8” on your Defender LTX M/S instead of 7” for OEM tire size which affects the tire section width and at the minimum rim width with 7” OE rims.. The worst is the 33 lbs. weight on your Defender LTX M/S which is 4~5 lbs heavier than OE Toyo A36/A23’s.
On my OE Toyo A23 225/55R19’s I did notice some rubbing marks to the front struts while I was doing the tire rotation.
