- 23 CX-5 Premium
100#Does anyone know the torque settings for the wheels? I will be putting wheel spacers on in a week or two and would like to use these settings for installing them
I saw the first post but visually the offsets do not always make sense to me. I have some 19" wheels that are 8.5" / +30 and tires that are 245/35/19. I know the bolt pattern is the same but wheel these fit? with those offsets, they are kind of a low profile tire. Volk SF Winning. Thanks,
I'm not an expert, but I would think that it will stick out quite a bit.
The +30 should be a bigger number, like 40-50(50 is the factory offset). ET 40mm, I believe is flush with the fender, 30mm sticks out 10mm. The smaller the number, the more it sticks out.
To find out how well desired wheels will fit, plug in specs for stock tire and rim and desired replacement.
http://www.rimsntires.com/specspro.jsp
So I have potential lead on some sport edition f7 wheels that I'm thinking of picking up to put winter tires on. The rims are 17x7.5 with an offset of 40. Do guys think these would work ok as winter wheels? I'm thinking it might actually be pretty good to have a slightly wider stance in the winter. But is it going to far and will I have rubbing issues?
Is there any list of which other Mazdas use the same exact wheel size as the Touring CX-5? (ie 17" X 7", 114.3mm X5, 67.1mm).
Thanks
Uh... pretty much any of them?
Okay, not the 2. But basically everything else.
It'd be a far shorter list to ask for which Mazdas in the last ten years wouldn't mount up the wheel from a CX-5 Touring.
Well... my 2010 3 has 17 x 7" wheels with a 5 x 114.3 bolt pattern and a 67.1 mm center bore. I believe the previous generation 6 used a 7" wide wheel, as well.
What's your major concern in exactly matching wheel dimensions?
