HT does raise boost to target in the 18-19 psi range with a nice taper to 16 psi at 6,000 rpm and then a slow taper after that, so you do not fall flat on your face after 6,000 like on stock tune. It also eliminates (selectively) the power restriction of the stock ECU in first and second gear. It also raises the load tables safely so that you can avoid the stock sharp load cut at the higher target boost levels of HT. It does all of this safely, maintaining safe AFR's and timing advance curve. As previously stated, it also is very smooth in operation.
It is very mod friendly, including with my catless 3 inch dp/rp. As pointed out it does have accurate MAF correction for most of the popular intakes.
It also stopped my boost spiking to 21 psi which I was getting with these mods on stock tune.
Is it as absolutely able to maximize power as the AP? No. Will it get you to the maximum SAFE and SMOOTH power on the stock turbo. Yes, or very close to it.
I'm not suggesting that AP is not good. It is. It is very good, even superior, in the hands of someone who knows how to tune safely. It can get you in a lot of trouble that HT will not, if you do not know what you are doing or if you think you do and push the envelope.
On the K04 it's not exactly how much absolute boost you can run, it's the compressor map. You can run 20 psi at 4,000 rpm, for instance, very safely if all other tuning paramaters are safe. You cannot run 20 psi (at least not very long) at 6,000 rpm.
BTW: There is no tune on the market that will make a wastegate flow better. It's maximum flow rate is purely mechanical, based on the size of its port and flapper valve. When that rate is exceeded, the turbo is going to boost creep and overboost, because the excess boost that cannot flow through the exhaust will overspin the turbo. All any tune can do is adjust boost to keep flow through below the wastegate's maximum, and that's going to be the same whether you are running AP, Standback or Hypertech.
