You can charge it with cans, just make sure to vacuum the system and make sure it holds for at least 5 minutes with out leaking pressure. Unless you have gauges and a pump it's best just to go back to whoever recovered the freon. I charge 15 to service ac, but that's just to hook uo gauges and charge or add freon. To remove the freon prices vary. The guy I use charges $40. Freon is serious shizzle. If it gets on your skin you can get frostbite, it will freeze your eyeballs if it blasts them. I'm not trying to scare anyone, just warning to use extreme caution when handling freon. Also replace any o rings as cheap leak insurance. Also add the proper amount of approved compressor oil to replace what was in the other condenser. 1-2 oz should work if you can't find specs. Good luck.
