The higher the offset the further into the wheelwell the wheel goes in. So if you get 17x7's and one had a 42 offset and the other one had a 48. The 42 would stick out further. For front wheel drive you usually want a higher offset so you can fit wider rims or have no rubbing. Hope that helps.
