I'm trying to fix my g/f's '00 LX protege CEL. I went to autozone and got the code of P0106, P0171, and P0507. I was told they are vacuum leak, system lean (bank 1) and idle too high.
I searched around the engine bay for leaks but didn't find anything, then I came to a totally loose screw on the valve cover.(See pic red circle) I found it because I saw it was shaking around in its hole when the engine is running. I tighten it, reset the CEL, but not sure if that was the problem. and I can't think of a way to find out.
So I'm just wondering what a loose screw can do. That was the only loose one on the valve cover, and one above it is a little loose but not too bad.
Josh
Josh
