C CHIQLES Member Contributor : mazdaspeed protege #0403 Nov 20, 2012 #141 how does that little radiator hold up to the heat?
B Boosted_Speed Member : MazdaSpeed Protege Nov 20, 2012 #142 well the radiator is dual core aluminum And i have 2 fans on it a Push Fan and a regular fan.. both mushimonto
S SCMP3 : 1993 miata Nov 20, 2012 #143 sweet. ill probably be going with a civic radiator as well....ill be running a large turbo as well
C CHIQLES Member Contributor : mazdaspeed protege #0403 Nov 20, 2012 #144 so pretty stable or do the fans come on alot?
B Boosted_Speed Member : MazdaSpeed Protege Nov 21, 2012 #145 very stable the push fan i have on at all times and the other one works like it if was factory
S shane02pro5 25ish_psi : New Caney TX Nov 21, 2012 #147 Nice! 3 words.... Throttle... Pedal... Modulation
2 2.0t03speed Member : 08.5 CWP Speed 3 Nov 21, 2012 #149 good luck with the new setup! Last edited: Nov 21, 2012
M mazdaspeedp Member Contributor : 2003.5 Mazdaspeed Protege Nov 23, 2012 #150 Sub. That Turbo is crazy lol. I wanna see a video and see how your car sounds. Im doing my build too i hope to have it running forsure this summer.
