well s***, my hg finally went. Im glad it wasnt anything else. I have been having numerous boiling coolant problems and radiator troubles over the past 5K miles.
First my lower radiator hose burst on the freeway then i pulled over and saw what happened. I just thought that the hose popped, so i replaced it on the side of the freeway but then i started the car and there was white smoke comming from everywhere. Tons was billowing out of my tail pipe. From this iand the boiling coolant problems i had i determined it is a headgasket failure.
Basically, I need to know how hard it is to do the hg and which would be a good alternative to the stock one.
Anyone know how much labor is involved and which one i should go with?
Also, can i get a thicker one to lower my compression down to 8.5:1 instead of 9:1 now?
I need help, and a hug (bang)
-B
-B
