Stock is more like 25-26mm to the fender (or it was for me). I measured from the lip of the wheel to a plumb bob line.
Assuming stock wheels are 18x7 et 50 :
19x9.5 et 35 is going to poke quite a bit. You're adding 63.5mm to the wheel width, 31.75 more inboard and the same outboard. You're also pushing the wheel out 15mm from stock so you're effectively moving the outside of your wheel out 46.75mm outward (poke of about 20mm or a little less than 1 inch) and 16mm MORE inboard. Sounds like it will fit but you're on your own on whether it will rub or clear the strut/wheel well.
19x9.5 et 35
Effective measurements (after offset)
Inward: (63.5 / 2) = 31.75 - 15 = 16.75mm inward
Outward: (63.5 / 2) = 31.75 + 15 = 46.75mm outward (~1.5 inches)
20x9 ET25
Inward: (50.8 / 2) = 25.4 - 25 = 0.04mm inward
Outward: (50.8 / 2) = 25.4 + 25 = 50.4mm outward (~2 inches)
Again, I can't answer whether they'll clear all the plastic and metal bits in the wheel well but yes, on paper, they look like they'll fit
