"Actuator for internal wastegate assembly. Special lower pressure (7 psi) version of the actuator similiar to the one found on the GT28RS/GT2871R. Has the Z bent rod which also works well on turbos with larger compressor housings to offset the diameter of the housing. *Machined Actuator bracket not included."
sweet...thanks a lot man. my car is missing and idling very erratic...i hope it does the trick. the diaphram has been blown for a very long time on my stocker
