As others have said, it won't give you any appreciative improvement.
If you look at the airflow versus engine RPM curves that K&V uses, you'll notice that the only place there's any perceivable difference is around the top of the RPM range. Particularly with the way that the transmission in the CX-5 is set up, we spend most of our time down at the low range of the RPM band. True, the K&V filter is cleanable and reusable, but by the time you factor in the cost of oil, cleaning solution, and the time spent cleaning and re-oiling the filter, you won't save anything.
K&N is a racing filter, but not a street one. Save your money.
