Dunno if you guys read any of my past threads but im having problems with my msp. My car started out bogging when I would try to accelerate from a stop. Any way i replaced the wga and that didnt help. Took my car into a shop, they said my cats were clogged so I stomped out both my cats and that didnt help. Present day and now my car isnt even drivable. It took me long enough but I finally realized my turbo had gone bad (For some reason after I used the Z-Max engine system which I suggest you dont use). My next plan is to pretty much take the turbo off and rebuild it. I already ordered a new oil line for schnits and gigs and the one on mine is startin to wear away it seems anyway. I also got a turbo to downpipe gasket, oil return line gasket, and turbo inlet gasket on the way also. All thats left that I need to order is the t25 turbo rebuild kit (about $80 or so).
If anyone can leave some hints for taking off the turbo or even rebuilding it for that matter, it would be greatly appreciated
Also, check out the pictures below and tell me what you think, and FYI- My exhaust would spit out white gas when I would try to punch it.
