I have just bought some 235/35x19 tyres to replace my existing 215/35's and asked my local garage to check the alignment/tracking, because the current tyres are showing an uneven wear pattern. The guy at the garage said, he would need to have figures to set everything to, because the change of wheel/tyre size from standard would effect how everything should be set.
He gave me a list of the default values for a standard Mazda6 sport, which has values for camber, toe-in, castor, KPI(SAI), lock angles, etc. I just wondered if anyone with a similar wheel/tyre setup has got a print out after their alignment was done, which may show how everything was set and if you are happy that everything is as it should be.
If someone could either list correct values or, preferably, attach a copy of the print out, that would be extremely helpful. I get the distinct impression that the mechanic doesn't want to touch it without me giving him the information beforehand.
