if you have info that will help everyone share it on the forums or delete you account kthanks.
yes. if you wanna go the easy way: unbolt knuckle from strut (remove the 2 bolts), unbolt from lower A-arm, disconnect brake lines AT THE STRUT, no need to do it at the caliper, you're going to use it anyway. bolt to new vehicle, bleed brakes, be done.So guys, after all said , is 5 lugs disc brakes direct swap to a 4 lugs drum brakes (front and rear ones)?
Thanks
did i miss anything?
I believe this only to be true on the front. The rear also requires the use of the links off the 5 luck vehicle. Someone correct me if wrong
I owned a '99 ZX2 up until this weekend when I bought a '99ES. This link will take you to a site that sells the used pars for the disk conversion.
http://www.zxtuner.com/product.sc?productId=232
I used to buy alot of my parts from this guy. I'll be doing the same shortly.
