2003 Mazda Protege5
106,000 Miles
Automatic Transmission
Okay, so I'll do my best to describe this for everyone. On my way home from work, I had the cruise set at 70mph on the interstate. As I began to crest a hill, the car downshifted to speed up to the 70 and suddenly had a loss of power. I immediately shut off the cruise and looked down just as the check engine light began flashing. I attempted to give the car gas and it just sounded like it was bouncing off a rev limiter. I coasted at 60 all the way to the next exit [1.5 miles] and pulled off. I opened the hood, all fluids appeared to be fine. Checked the gas cap as well. By the time I had gotten off the exit, the check engine light was on and not flashing. After leaving the car off for a few minutes, I turned it back on and everything seemed to run fine.
I drove it 19 miles home, never going over 52mph. The car seemed to run fine the entire way home, no hiccups or anything. Does anyone have an idea what this could be? Thanks.
EDIT: I should also mention I plan on getting codes read tomorrow if possible.
106,000 Miles
