So if I just replace the struts with stock struts, do I need to buy new coils? Do they come with the new struts?
new springs are not included with the struts - the assemblies have to be disassembled and reassebled.
So are the springs normally replaced or are they reused?
I just called the local mechanic that I usually use whenever I cant work on my car, $400 to replace the front struts, $450 to replace the back. Since Im coming onto 100k miles, timing belt would be $759 (includes timing belt, drive belts, water pump seal, and other seals/gaskets). Pricey...
