- Canada
I would fix but my main concern is that it seems to be something normal between those 2.5 engines what if i fix and it happens again lol, its just messed up having to replace a engine with only 68k miles on it yk
If you do a bit more reading you'll find that the cylinder head was redesigned in 2021 to address this issue. So if the dealership or whoever sources the replacement from Mazda, or from a 2021+ model with the same engine, it should no longer have this issue.
